Hi All,
got a radiator I require some help with. I have been decorating my living room and have had larger rads fitted,the plumber hung and piped them all up but didn't fill as I was still decorating and wanted to remove them again. I fitted and filled them myself, but I have a slight problem. Its a double panel double convector, when I filled it I just open the lockshield valve and thermostatic valve with the bleed nipple shut, then bled as normal.
The problem is its getting lovely and warm on the top half but only luke warm at the bottom. I have tried to bleed the rad normally but as soon as I open it I get water and no air. I was wondering if I had some sort of air trap or if I haven't filled it correctly.
Someone suggested closing both valves and opening the bleed valve and the plug on the other side then opening one of the valves to force the air out??
Just looking for some advice so I'm getting the best out of my nice shiny new rad!!
Thanks in advance!!
Thanks in advance!!
