- Joined
- 27 Jan 2008
- Messages
- 29,428
- Reaction score
- 3,615
- Location
- Country
There are many videos on the internet which are really bad but I am not looking at them what I looked at was a reasonable good video showing how to change a class II light fitting with ceiling rose to a class I fitting with GU10 lamps. On watching I noted:-
1) Using MCB to isolate without checking earth system in use.
2) No lock on MCB or even tape over it or notice hung on it.
3) Use of contact less tester to prove dead although he did go to lengths to test the contact less tester was working.
4) No test to see if there was a working earth connected to lamp.
Don't get me wrong here it was a reasonable video and I am sure many DIY people will benefit from watching it but I was in particular no happy with no earth test.
I started to think and realised years ago my Martindale tester had a bulb in it and so simply testing between line and earth may not be the correct method but did give some assurance the earth existed. However with my new Neon Martindale tester likely neons would light even if the earth was disconnected as they draw so little current. OK I use a earth loop impedance tester but DIY guys will not have one of these. Not happy showing how to build a bulb tester so what method can be used by DIY guy to test earth?
As to proving dead well switch on lamp switch off isolator check lamp goes off then switch on again see lamp lights so proving bulb not blown and then off again with isolator with lock, tie wrap, tape, notice or something to show it has been switched off likely better than all his contact less testers and with isolator does not really matter is TN or TT still safe.
But still can't think of a safe way to tell a DIY guy how to test if the earth is good before swapping class II to class I so how would you without low ohm meter, or earth loop impedance tester check for a good earth.
