I recently moved into a new house with a type of wood floor that I haven't seen before. The previous owners noted that it was quite expensive when it was put in (quite a few years ago I think).
The floor covers probably about 35-40 square metres of the ground floor, through the living room, dining room, entrance hall, and toilet.
(sorry for the bad picture)
It appears that the surface layer is some kind of wood veneer with inlaid edging in a darker wood, but I'm not sure if it may be laid on top of some kind of vinyl, as it's warping (bubbling) upwards slightly in some areas - the bubbling bit seem to be confined to a couple of areas in the larger rooms, so it looks like the warping is in the layer or sheet the strips are affixed to rather than individual veneer strips. It's pretty cold to walk on, and I suspect that the base floor underneath is concrete, but haven't been able to confirm (and the surveyor refused to comment on it)
I'd like to replace it with something warmer and better looking, but probably can't afford to do the whole area, so was considering tackling the smaller rooms (toilet and entranceway) first.
Has anyone seen this kind of flooring before, or have any ideas what I'm likely to find if I start trying to pull it up, or any obvious pitfalls? I don't want to start digging holes in the floor until I have a reasonable idea of what I'm dealing with.
The smaller rooms don't have any signs of warping, so I've been wondering about whether it would be possible to lay something over this instead of ripping it up. It does seem fairly solid and doesn't show any signs of movement except the noted bubbling in the middle of the larger room.
Stevos
Stevos
