Recently installed double glazing gaps..
10 Feb 2014
Surrey
So the double glazing that was recently installed has some gaps around the frames and the wall.
Whats the best thing to use to fill these cracks?
if you are the installer please say so
we are trying to be helpful and the advice above is spot on if you have paid someone to do the job
of course if you have fitted them yourself you will get other help but will also need to pay building control to certify the installation if up to standard
of course if you have fitted them yourself you will need to pay building control to certify the installation if up to standard
So I believe my question was simple.
I'll be more precise.
Is it acceptable to use decorators caulk to fill 1 and 2mm cracks/gaps opened up around the double glazed window frame?
are they internal or external ??
gaps are unusual if the job was done correctly in the first place
do you have any pictures please
Sorry not just yet, but Anglian installed the windows, in two rooms there are gaps all the way around the window frame and leaks lot of air and in another room the double glazed door to the balcony is whistling :/
Back to the window frame in the original question, the gaps are internal, so I'd like to know if using decorators caulk is ok to fill these gaps.
yes thats fine
but if you have air flow i would suggest they haven't properly filled the voids fully between the new windows and the wall possibly causing cold spots??
yes thats fine
In the other room is definitely worse, you can see cracks around the whole frame causing the room's temperature to be like it is outside (its an empty room atm).
The installation was about 7 months ago, how likely is it the company who installed it will come and resolve these issues?
can you prize back any trim easily in the coldest rooms to see if there's a good level off fill??
definatly get them back if theres draughts but heat the room for several days to see how it works out first
Trim, doesnt really have much existing sealant if thats what you mean by trim.
Not sure if its worth calling the installer, they'll take forever to come and its not worth it.
So I'll just use some decorating sealant...? Or should I go to Anglian?
trim is added plastic/wooden moldings to cover gaps in the same way architrave around a door fills the gap between door frame and wall
In that case theres no trim, on the inside at least.
EDIT: Ignore the prev comment. Here are some pics;
The whole room has been plastered, yeah?? By the looks of it the fitters have left the tape on for that reason! As long as its sealed outside the plaster should go straight into the frame leaving no gaps! All that remains then is to Stanley round, pull tape off, clean frame, masking tape round, caulk, masking tape, paint, done!
