Air Brick Problem
9 Mar 2014
Cleveland
Hi I have a problem with my air bricks because the concrete floor has covered nearly half of the air bricks.
I dont know if there is any product I can buy to rectify this or if anyone else has had this same problem then please share your views.
I have attached pictures.
Why not just neatly cut away some of the concrete, and cover the opening
with stiff mesh?
with stiff mesh?
will that stop water from going in though?
I seen a vent called 'snorkelvent' earlier. I think thats my best bet. Quite expensive.
with stiff mesh?
If you put a small raised wall of concrete around it, water shouldn't be a problem.
A bit Heath Robinson admittedly, but cheap; periscope would probably look better but ££?
