- Joined
- 27 Jan 2008
- Messages
- 28,913
- Reaction score
- 3,538
- Location
- Country
I did check google shower instructions got Triton showers so read that and it states: is appliance is intended to be permanently connected to the fixed wiring of the electrical mains system.
It also says: Switch off when not in use but states it is a general instruction for all electrical appliances and clearly contradicts the first instruction.
I have had issues with oven isolators being used both simply the clock stops and has to be reset before oven works and loss of cooling fans so carcase over heats.
Around the house there are many isolators from the grid switch supplying stuff in kitchen to FCU with immersion heaters and in the main I would never switch any of them off unless I needed to work on the appliance.
I question the whole idea of switching off a shower or cooker isolator after each time the item is used specially where it's on a pull sting as we all know these have a limited life.
The point is I suppose what is not in use? When we go on holiday the house is not in use and yes switch off shower but with a family of 4 switching off showers and the like seems pointless when not being used far better when they are in use and see the reaction!
To say switch off when not in daily use would make sense maybe even switch off when not in weekly use but I can't even get my wife to unplug phone charger when not in use what chance would I have with shower?
