- Joined
- 14 Jun 2026
- Messages
- 3
- Reaction score
- 0
- Country
Hello
Apologies if this is the wrong forum but as its "electrical" related i thought i would try here first
My daughter has a Triton Shower in the house she moved in to, this unit is a low end model and does not have an on/off switch on the unit itself so she has been using the isolator pull cord to switch it "on and off" otherwise the power light remains on all the time.
Consequently the switch has now burnt out and needs replacing, having a read around it appears as if the isolator should not be used as an on off switch which means the unit is powered up all the time
The Triton manual says: " In normal use, it is in order to leave the water supply permanently on to the shower unit, but as with most electrical appliances, the unit must be switched off at the isolating switch when not in use."
so what constitutes "not in use" as with any normal person not in use to me means when you are not getting a shower or does it mean when it will not be used for an extended period of time ?
Any opinions or advice please
