... except that there are only 3 different phasesOr maybe it all runs a 15 phase motor?
I assume he meant 15 single-phase feeds to domestic services - i.e. the five 3-phase outgoing cables you can see at the bottom.Where do you see 15 feeds?
If you could find, or generate, a 15-phase supply to power it from!If such a thing existed, it would be silky smooth!!!
... plus a single-phase or 3-phase motor (or a steam engine or whatever!!) to rotate one of the 15-phase oneswell you'd just need two 15 phase motors
Indeed - interesting question, particularly given that I imagine that those outgoing cables disappearing into the floor will probably have been damaged ... unless, of course, there were some place further downstream where consumers could have been switched to a different source of supply.I am wondering how long the customers were without power as it would take some time to replace the burnt out items.
I definitely need to think about that - maybe the thinking will become easier after I have opened a bottle... six phases from a phase shift transformer - one set of three output in star, one set output in delta. 30 deg. shift between the two sets of outputs.
