This happened on Saturday at a LOW VOLTAGE Substation, (no Transformer), not sure why at this time.....but looks like a leaking cable termination box decided to take early retirement....
it should look very similar to this.....
but after the incident it now looks like this.....
Check out the how the fault has burnt away the 1/4 inch thick framework of the board....., the termination boxes should be filled with bitumen, all that was left inside was pools of molten brass where the heat of the fault had melted the connections, and the bitumen vapourised.....
These were the 315A fuses
