Quite so.I think you have hit the nail on the head. As long as the name differentiates between an inductive transformer and another device then not so bad.
Indeed. I was brought up on DC-DC inverters (usually 12V in and around 250V-300V out), used to power valve-based equipment from car batteries - and I still have examples not only of them but also of both rotary converters and synchronous vibrators somewhere in some dusty corner of my cellar! However, those 'inverters' I built and used were not really SMPSs in the modern sense - they were 12V roughly sine-wave oscillators which fed a step-up true (inductive) transformer and rectifier/regulator - and necessarily at quite low frequency (hence large transformers), since the power transistors of the '60s could not cope with much in the way of frequency! Rotary converters were somewhat similar in concept, but the vibrators+transformers were, of course, an early electro-mechanical version of an 'SMPS'!However well before the lighting manufacturer started making switch mode high frequency devices to power 12 volt lights the welding machine manufactures started to produce the inverter which replaced the welding transformer giving far better control with a better feel and much lighter. ... Since the name "Inverter" has already been used to describe these devices I see little point in using another name for basic same device. ... Be it to raise or lower the voltage the electronic device to replace the transformer as been called an inverter. Often used with DC input to raise the voltage. In the old days it was called a rotary converter we also had the synchronous vibrator with transformer to raise voltage in the old days.
You're welcome. The amateur service is obviously not the only one to be considered - but I think the main point is that any wiring would be so short in comparison with the wavelength at 40Hz that any radiation, hence possible EMC, would be minimal.My thanks to point out the 2 or 4 meter limit also the frequency at 40 kHz amateur radio starts at 136 kHz so unlikely to cause interference.
Do they really? That sounds rather crazy, and I find it hard to see why they would do that!Some of the HF fluorescent units go into the Ghz range so very different.
