I recently purchased a house, heating system "needs attention" was in the particulars. When we looked around, the pipes in the airing cupboard were warm and the boiler was running, so we thought it was probably just the valve or something.
Fast forward to last week when we completed and when the heating system was switched on from cold the boiler ran for a couple of minutes the pipe coming out got too hot to hold and then the boiler stopped. After a few minutes of cooling it would run again and after about an hour the pipes around the pump would begin to become warm. After a few hours we can get luke warm water (probably around 40°C) out of the taps but the radiators never heat (although water can be heard flowing through them).
I have "Home Emergency" cover from my bank, so called them out and after 45 mins of poking about, sticking a magnet to the copper pipe just below the pump, taking some water samples and not going in the loft (because there is nowhere to lean ladder against and it's not boarded!) the diagnosis was "your pipes are blocked and if it was my house I'd replace the boiler and pipework", took lots of photos with an iPhone and went away again saying something about "they'll be in touch".
A friend of mine suggested that getting a reputable local plumber to do a power flush may be the solution here (rather than replumbing the house) but he's no more of a plumber than I am an astronaut.
For reference the water temp leaving the boiler is 74C, return is 30C after running on continuous all day, the divert valve operates correctly and I took big screw out pump and it was going around (and some water came out). When I opened the bleed valves above the divert valve, there was no air, just a trickle of water. The samples of water taken were "reasonably clear with some chunks in" as the engineer said on the phone to his office this PM.
Does anyone have any thoughts on this? Does it sound like a power flush will be successful?
