Hi, I'm still having issues with my 937 in that I only get HW at low flow rates. As soon as the flow reaches a higher level something restricts the flow and it all but stops particularly on the 3rd floor of the house!
I've checked both stopcock and boiler inlet filters and they are squeaky clean. I've disconnected the cold feed to check for inlet flow and that's OK too. But when the HW outlet is diverted direct to drain (used a piece of pipe to do so) the flow reduces to a dribble, barely 2.5 l/min!, so whats's going on?
Could the flow sensor be failing and causing a blockage at higher flow rates. Do they usually cause problems?
There's nothing else in the HW circuit that can restrict the flow as far as I can see on the diagram.
