The H/W side of a combi' boiler is instantaneous.
Example - you open up the hot water tap and the boiler fires up you close the tap and the combi' switches off (no pump involved).
servotech,
Pump runs for DHW on 90% of combis for hw
servotech,
Woofter Botch boilers spin their pumps in hot water mode.
Thought you'd know that Mr Bisby.![]()
Not many don't.
servotech,
guessman that not what it says in a lot of manufacturers instructions it says its to dissipate heat ,
As flame dies away ? once gas valve shuts the burners are as good as dam i immediatley extinguished and if it was to clear any products this would take seconds not the several minutes fans over run for
