hi all hopefully the pic of my problem has uploaded. when i flush the loo it doesnt shut off, i gguess it must be a washer of some sort, i have taken the large nut off on the left and i can feel something rubber in there, is this what i need to replace?
thasnks
Bill
thasnks
Bill
It looks like a WC cistern frame, did you gain access via the flush plate at the front?
It could be your flush valve washer that's faulty or damaged & not the inlet valve.
Why is a flexible fitting with isolating valve INSIDE a cistern
There is something a bit weird about that lay out can't quite get my head around it.
But as your valve looks a bit odd getting a kit with some of the more obscure ones might be the best bet
http://www.screwfix.com/p/ball-valve-spares-107pcs/98525#
