I want to repair a section of 8mm microbore heating pipe that got a nick when removing floorboards... This pipe is below floor level and there is no lower outlet to enable me to drain it (ie it's below all the radiators) before I cut out the nicked section and fit a compression fitting. Is there a smart way to drain this? Assuming valves work on radiators and I've turned them all off at both ends I don't expect there'll be much water to catch but was wondering if there was another way?
