I purchased a garage many years ago that is part of a block of 4 garages; the backs of 2 of the garages join onto the backs of the other 2. Water leaks into the back of the garage between the join of the roof and the wall and I would like to find a solution to this. In the photograph mine is the garage with the white door. To be fair, the guy that sold me the garage told me that the roof was leaking. Over the years, there have been attempts to repair the roof with limited success. I would like a permanent solution to the problem. The problem lies with the roof pitch which goes the opposite way to normal meaning rain water travels to the back of the garage. There is a middle gully to drain off water but water finds its way into the back of my garage and gets worse when leaves clog up the gully. The easiest solution is to add a further covering to all the garage roofs but for this to be effective all 4 garages need to be done and not sure if all owners would agree with this. Also, I’m not sure I wouldn’t be looking at repairing this in years to come. Another possible solution is to remove the roof, add layers of bricks to change the pitch of the roof and have water draining off the front of the garage. The problem with this is that the asbestos sheeting on the roof overlaps with the next door garage. The person that made this suggestion said he would use a grinder to cut through the sheets but I was horrified at this suggestion and I wouldn’t let someone be exposed to the risk of inhaling dust from grinding asbestos sheeting. Someone suggested building a garage within the garage – perhaps not as daft as it sounds as the walls are quite high. Anyway, has anybody got any thoughts on how to get me a dry garage?[/img]
