Baxi back boiler & gas fire service costs
14 Aug 2007
Is there a ball park figure for servicing a Baxi 552 including land lord cert.
We priced one the other day and were told we were way to dear !!
Ask them if they want someone to do the work to make sure it's safe for the occupants, or someone to just sign the certificate to say it is.
What was your price anyway? Any other appliances?
Yep - sorry about that - didn't read the post properly.
£75 for the service
:oops:
IF the boiler has been properly serviced within the last two years and is burning cleanly then I would charge £74 to service plus £35 for a CP12 at the same time.
But if not serviced and not burning cleanly then I treat it as a repair and would charge about £124 plus £35 for the certificate.
They also need proper ventilation present which some do not.
Tony
My boss priced the job at £120, that was a thermocouple as well, he usually changes them at the same time as he services the BB.
£120 is a tad on the high side mate!, why change a thermocouple that is perfectly fine ?
£75 is perfect. 100% profit no parts required.!
Tony
Tony, if the boiler is working but is just burning yellow. And a service would cure this problem why on earth are you charging for a breakdown!!
That's a bit naughty that tbh!
What is the point servicing a boiler if it's got a lovely blue flame!! You can not expect to rock up to a bbu expect it all to be spotless!
Come on be fair.
Tony
Jesus Tony you come out with some good ones, i suppose you charge more for a dirty one as its hard to take Henry on the tube?
Come on be fair.
I think its perfectly fair!
That model needs servicing every year.
If its burning yellow I classify that as AR and it should be turned off! That means that it is an urgent visit which I aim to do the same or next day.
I remove the burner and wash it out as well as scraping every gas way in the c.i. heat exchanger. That takes about two hours including servicing the fire front and with proper testing and the gas certificate.
A service to me means a routine service on a boiler which is working fine and can be done whenever its convenient and typically within seven days. But NOT as a same day emergency on a broken down boiler.
Be aware that many engineers refuse to work on them!
Tony
It is up to an individual to decide on his charging structure - but how can you justify £35 for a piece of paper ? A proper service on a BBU would entail the elements of a CP12 (apart from maybe a tightness test for some)
