Is all copper tube created equal?
27 Aug 2003
London
If I want some 15mm BS EN 1057 Type X, can I buy any make, from any supplier, or are some makes/suppliers more equal than others? :wink:
Ditto solder ring/end-feed fittings.
As someone who started plumbing in the 70's and during the copper shortage / silly prices we had to install some very dubious imported copper tube.
It would snap or ripple when you tried to bend it and the quality control on the dia was zero.
Therefore I only used Yorkshire or Wednesbury tube whenever I could. But I'm sure most of the imported copper these days is fine.
Same with fittings, always used branded. Yorkshire, Delcop etc
With 15 mm its pretty irrelevant.
With 22 mm the same if only using straight lengths.
But if you are bending it then it always seems to me that some brands are more prone to rippling than others.
I rarely bend as it does not look nice although it gives less flow resistance for gas.
In fact I usually detemper it with heat before bending.
It may be a false feeling but the Black Label as widely sold seems slightly better!
Tony
Thanks.
Should have said I'm not really bothered about price, as I don't want much, which does also impose a requirement for a supplier who sells individual tubes rather than packs of 10.
Aye
:mrgreen:
Tony
I think bends look better maybe its because i apprieciate being able to use a bending machine properly unlike the rough buggers that use elbows everywhere,
If you cant bend 22mm without heating up to prevent rippling may i suggest learning how to use a bending machine properly
Detemper the tube??? :lol: :lol:
I've heard it all now..., jeez. :lol:
You haven't a clue Tony. :wink:
My dog had a distemper vaccination.
Does that mean he won't ripple if I put him in the benders?
He should anneal them like wot I do. Anneal down and bend them over my knee.
