Hello everybody,
I am new I am the beginner and I need your help.
I need to supply the power to the garage. The garage is about 37 meters from the house.It`s a new house and I wouldn`t like to cut the walls to take it from the CU. I need a confirmation and an advice am I thinking correctly. It will be checked by a qualified electrician. But I would like to know am I thinking in a right way. What I am going to do:
1. Split the tails by a connector block (using the same tails size- 25mm)
2. Install the enclosure with 100amp RCD with 40amp MCB- use the 25mm wires to connect the connector block with the enclosure
3. Run the armoured cable 16mm (because of the voltage drop)connect it to that mcb, bury it and connect to the 40 Amp CU in the garage (lights- 6amp and 32 final ring for sockets)
4. I am going to use three core armoured cable and use one core as an earth.
If I am thinking in a wrong way show me the right one please.
Thank`s
Thank`s
