Intergas 24/18 locking out 'fault code 4'
Status
Not open for further replies.
Hhhmmmm a bit more background reading might be in order.
Including maybe the forum rules on giving gas advice in the public forum.
Even if you are capable, the next person might not be and could cause themselves serious harm following advice not meant for them.
If you are as good as you claim and formerly CORGI then why not join the Combustion Chamber and find out more?
Would certainly put an interesting slant on the drivel you just posted ;)
I'd rather be wrongly classed as a smart a**e than act like a complete p***k Dan. Who the f**k do yo think you are making a totally unwarranted comment like that. Where in any of my posts have I said anything remotely derogatory or caused offence. If anything YOU are the smart a**e making your silly little immature cocky comments.
Don't you think that those words are pretty derogatory towards Dan?
In fact you are lucky that the moderators did not delete it. Amongst the forum rules, which you don't seem to have read, you will see that abusive postings are not allowed.
In contrast, your use of abusive language makes you appear to be an uneducated building site worker!
Tony
Cheers Tony.
I have skin thick enough to take internet insults.
Some people just don't like being told how it is :lol:.
If Tunni joined the Combustion Chamber I am sure things would be different ;).
I don't have modding rights here otherwise I would ban you and Tunni for both being abusive !
And in return Id remove your posting rights for giving unsound gas advice!!!!
Still crushing gas pipes in a vice to get round obstacles??????
Regards U6
Tell me u2 x 3.
If I take 3m of 28mm copper pipe and run a 747 along the length of it so the tube is egg shaped.
Is the volume the same, less or more.
Knew you'd be along soon.
To answer that question is need you to clarify the following ...
Which of the 6, 747 variants?
Weight at time of crushing the tube.
Let's for the sake of it presume you mean a 747-400 @ MTOW (330,000kg), then the volume of 3m of 28mm tube would be less, in fact it's likely that it would be zero because it would be bloody flat!
Do you want to explain the effect that disturbing the pipe by crushing it would have on laminar flow and pressure drop?
Regards U6
The politician answer :lol: :lol:
Assuming it's fit for purpose and the right size where's the problem with 0 shaped pipe instead of O shaped
Are you Seriously suggesting that crushing a gas pipe in a vice is good practice and acceptable?
I thought better of you, seems protecting your friend has blinkered what you used to practice when you worked.
Disappointed. U6
Disappointed. U6
I'm not suggesting anything of the kind, I would cut a chase behind the obstruction. But that wasn't the question which you have fudge quite conveniently. :lol:
U6, Thank you for your insight into Agiles background. From his comments he clearly cannot grasp the simple fact that this post ONLY turned adversarial/abusive when Dan WITHOUT ANY provocation whatsoever posted derogatorty comments and ended up insulting me. Duh!
These pair of conceited and arrogant clowns go on to say I should read the forum rules!
Ironically I totally agree with what Dan says regarding not giving gas advice that could be used by someone who is not competent. However I will not stand by and allow him to make derogatory comments and insult me.[/u][/i]
Dan allow me to quote you:- "Call a Gas Safe registered engineer and try not to sound like a smart ar********"
If you don't think that's a rude arrogant insult then...well go figure, it speaks volumes about you!
Status
