I have a vokera compact 24, the initial problem was that it would not ignite to provide DHW or CH, it DIDN'T goto lockout. This problem was solved by a heating engineer who fitted a new ignition module on the circuit board, the boiler ignited and worked fine.
After only an hour or so the boiler then went into lock out at ignition, the engineer has returned, tested it and found no other faults, spoke to vokera technical support who said it was a faulty ignition module, which was changed again, and again, only for the same thing to happen!
Does anybody have any ideas as it is driving the engineer and myself a little mad.
Cheers fred
Cheers fred
