RCD FCU price difference
14 Sep 2006
Liverpool
Looking at the availability of RCD FCUs shows that the 'Powerbreaker' make is nearly three times the price of the cheaper model.
http://www.tlc-direct.co.uk/Main_In...ge/RCD_Protected_Range_2/index.html#KBRCD6000
Anyone got an opinion if it's worth the extra, or is the cheaper one good enough?
Realise that some are latching whilst other are non-latching, but can't see that as being important. Or am I missing something?
I'm with Simon on this one. I thought it was my bad luck as i had a few fail on me - I stopped usiing them a while ago as I don't like to go back to fix things.
I also found
Not tripping when the test button is pressed.
Buzzing when the test button is pressed.
Buzzing when the test button isn't pressed.
Exploding when the test button is pressed.
I never did have one
Exploding when the test button isn't pressed.
I think we may have answered your question SNM?
Before the days of RCBOs, I got a carton of Powerbreaker RCD sockets, and I and my neighbour fitted them in our garages, and I put one in my old mum's house for the lawnmower.
One was DOA (makers sent me a new one, no questions asked) and two of mine later failed RCD test (one failed to trip, one failed to reset) and in my mum's an internal plastic part broke.
So I don't think they're a good make.
IIRC I got mum a Crabtree which seemed better.
I have installed a few BG units and had no problem with them and they are not expensive.
Kind Regards,
DS
I have had RCD on the consumer unit since around 1992 so never used FCU or Sockets with RCD's built in expect one metal clad 10 mA and I found the test button also tripped the 30 mA trip.
Not looking good.
Been asked to put a few in for Christmas lighting. The guy doesn't want to be bothered with any alterations to the CU, so not sure what to do now.
Odd that they're still on the market considering they've been around for years.
I did actually put a few in my parent's house some years ago, and as far as I'm aware, they never caused any problems. Having said that, I didn't have an RCD tester at the time.
RCDs come with a button marked "test" and an instruction to do so every 90 days. That should give some indication of the manufacturer's faith in their product.
http://www.mkelectric.com/en-gb/Products/WD/logicplus/conectionunits/RCDCU/Pages/K385WHI.aspx
It could be important if you need one sort but fit the other.
http://www.tlc-direct.co.uk/Technical/Accessories/RcdSockets/RcdSockets.htm
What's going to be supplied by the FCU?
Not looking good. Been asked to put a few in for Christmas lighting. The guy doesn't want to be bothered with any alterations to the CU, so not sure what to do now.
A few? How much Christmas lighting are we talking about?! If you're concerned about RCD FCUs, what about sockets and plug-in RCD adaptors - which are easily removed/replaced?
Odd that they're still on the market considering they've been around for years. I did actually put a few in my parent's house some years ago, and as far as I'm aware, they never caused any problems. Having said that, I didn't have an RCD tester at the time.
Don't forget that you don't see on the 6 o'clock news every day reports about all the airliners that haven't crashed that day, or about all the people who have not been mugged, raped or murdered. Despite the anecdotes you are hearing about, I would imagine that the great majority of RCD FCUs, of all 'reputable' makes, have been in service for years without any problems.
Hmmm. If you look at its manual, your car probably comes with instructions to check its tyres (and various other things) prior to every journey, which would be nearly every day for many people. I think the Highway Code says (or said) much the same. Is that a reflection on the perceived life expectancy of tyres etc.?
It doesn't really matter for Christmas lights (or many other applications). 'Latching' ('active') ones trip in the event of a power cute etc., and so have to be be reset before power is restored to the circuit. That could be valuable/important functionality if, say, power tools are connected to the circuit (which might suddenly come on when power is restored after a 'cut', if one is using a 'passive', non-latching, device) but in the case of lights etc. would really have little more than 'nuisance' value.
No, its expected by the IAM, and the Police that it is the responsibility of the driver to check that his vehicle is roadworthy before every journey.
Its an offence or two to drive if it is not fit.
But how many people do that?
Or test their RCDs every month, or whatever.
Indeed.
But of those, how many have exhibited no problems because they are OK, and how many because there has never an event where they needed to perform?
The airbags in my car have never had any problems.
... a power cute ...
:?: :lol:
