I may be out of my technological depth here! Anyone?
Theres not much in them, and the special bit seems deeply embossed in the tip.
I have various failed all plastic ones and would be happy to post you one to disect john
[quote="scousespark";p="3227612 said:";p="3227612"]Given you have paid at least enough over the year (I would imagine) to cover your services, I would get Homecare back out to find the fault.
Otherwise, you are paying twice.
Your experiment does demonstrate the problem you have. You got a result twice then nothing. Hopefully, you will get a positive reading next time an electrician is on site. Good luck mate.
Govenor,
Humour us.
Are the trays metal, plastic or ceramic and are the outlets metal or plastic.
Your light-pen display in the DNO box was useful in that it illustrates that they tend to produce poor objective evidence when chasing problems.
Indeed - and if if it doesn't happen next time an electrician in on site, at least the OP can show him/her the videos.Your experiment does demonstrate the problem you have. You got a result twice then nothing. Hopefully, you will get a positive reading next time an electrician is on site. Good luck mate.
That's interesting. Of course, whether one could identify the nature of 'the special bit', even if one got at it, is perhaps a different matter!Theres not much in them, and the special bit seems deeply embossed in the tip.
That's very kind, and I might even take you up on that. However, I know that a friend of mine had a dead one, so if he hasn't thrown it out, I could probably get it off him. I'll check.I have various failed all plastic ones and would be happy to post you one to disect john
I don't exactly follow what you mean but could your leaning on a strut be putting pressure on a joist causing the pipe to come into contact with a (worn) cable which it may do when it expands when hot?if I lean on a particular roof strut and put my volt-pen to the pipework it lights up!
Thanks, but that is talking about the standard capacitive coupling method which we all 'know and love', relying on capacitive coupling to earth through the body of a person holding the barrel of the device ...http://www.testequipmentdepot.com/application-notes/pdf/electrical-test/understanding-capacitive-voltage-sensors_an.PDF
That does not therefore solve the mystery of those devices which (if they existMr Fluke said:The capacitive voltage sensor works because when you hold the barrel in your hand and place the tip near a live conductor, you are inserting the high impedance sensing element into a capacitively coupled series circuit. As in the previous example, your hand and body form a relatively large capacitor coupled to the floor. The sensor tip is a small capacitor coupled to the live voltage.
An electrostatic field (which is what you say Fluke are talking about) is a different kettle of fish,
Thinking aloud ... I'm starting to wonder whether all the OP's investigations and experiments are telling us about little other than the idiosyncracies, unpredicability/variability and 'unreliability' of these various 'voltage detecting' gizmos and that maybe the truth is that there is no real 'problem' - i.e. that any true potential differences between anything and anything else are extremely small.
As I understand it, the tingling the OP has experienced has been mainly/always experienced in broken skin. Once the highly protective (and quite insulating) skin is broken, the exposed tissues can be very sensitive to even very low voltages, particular if wet - as many/most people know if they have tried a battery on their tongue (although, admittedly, a lot of that is due to electrolysis)!
