I am planning to get an extension built. I live in London. I got the following quote and I would be grateful if you could give me some feedback about the price, whether you think it is reasonable
Kitchen
-Disconnect existing kitchen units, take of floor covering £290
-Take dawn brick wall forming toilet outside and crick up the doorway with necessary dpc match up £430
-Make good the walls allowing for final finishes
ainting,allow for plastering £340
-Replace existing ceiling with new one with plastered finish £350
-Painting all walls and ceilings £290
-Rewire the kitchen sockets and lighting circuit allowing for six spotlight on the ceiling and upgrade of consumer unit £770
-Alteration to plumbing £280
-Reinforce floor with ditra matt and tile with slates supplied by client £460 (all surface before kitchen goes in)
-fit kitchen units, apliences,worktops £1560
-Create new structural opening at the back of the kitchen enlarging back wall opening going to extension, including installation of 203/203 uc46 steel beams£1360
-Coast of skip £200
Total: £6330+vat
Back Extension
Form strip foundation 3mtrs long away from the house and 3mtrs width 1000mm deep and 600mm wide with c4 concreate £2300(dig soil out to required depth ,prepare underpinning of two corners of the house.
-build two curses of engineering bricks up to 150mm above the ground then fit damp curse protection, before the blocks go on £1100
-build walls using 200mm Thermalite blocks , with opening for French door at the back(with necessary structural opening over the doors catnic c71) ,fit 40mm kingspan to outer side of the walls with over lay of cedar thermal clading £3090
Form flat roof with opening for flush glazed panel with insulated curb and polymeric resin finish on the top of warm deck roof(type of the roof where 100mm of kingspan insulation goes on the top of the roof)fit all necessary lead flushing along joint of the roof and masonry wall £2390 price for the glazed panel to be confirmed once the size is confirmed
Form insulated concrete slab to match the floor high in the existing kitchen(concreate floor with 3mm damp membrane and 100mm of king span insulation with overlay of 70mm of concreate .£1730
-Fit dac and dub plasterboards on the walls and ceiling £1160
-plaster the walls and ceiling £1050
-allow for extending electrics £680
-allow for extending central heating £630
fit scirtings around newly formed walls £320
- -provide skips for duration of works £880
- total:£15,330+vat
Kitchen
-Coast of skip £200
Total: £6330+vat
Back Extension
- total:£15,330+vat
