Id like to install a programmable light switch one of my rooms for a couple of weeks as a security measure.
There are currently two 1 gang 2 way switches fitted at each end of the room.
The lights can be switched on and off from either switch
Id like to fit one of these
http://www.greenbrook.co.uk/proddetail.php?prod=T40S-C&cat=4
Ive taken a look at the instructions but they are not very clear so im not sure whether this product would be suitable or not and how it should be wired up.
i popped the current switches off the wall an this is how the wiring looks:
Switch 1 has 5 wires going into it.
Switch 2 has 3 wires going into it
The back of the timer switch looks like this:
View media item 87162
Id like to wire the timer to the 3 wire switch if possible
Can anyone advise whether the switch ive chosen will be compatible and how best to wire it?
Side Note: On removing both switches, the earth wires are not connected to anything..
Is this reason for concern and something i should fix as a priority?
