I would to insulate under my lounge that is suspended timber and I am in two minds what to use, celotex or sheep's wool ? I am thinking sheep's wool since will be easier to use. I plan to use that netting used on scaffholding to create baskets for the sheep's wool, I know i will also need a vapour membrane to go over the joists with floorboards then put on top.
My concerns are that the other ground floor rooms wont have any insulation or vapour membrane, will this cause problems with moisture condensing under the lounge ?
Another potential issue is i plan to run cables in some conduit under the lounge floor for AV equipment, will having the conduit come up through the floor cause problems ? with warm air travelling down the inside of the conduit ?
