My house is a 1991 5 bed detached. It has concrete roof tiles with sarking under and factory made roof trusses. The header tanks for domestic hot water and the gas fired central heating are installed on a 4 foot square platform, about 18" above the ceiling joists. All this is as originally built. I have increased the loft insulation to the currently recomended level, except under the platform where there is none. Soffit ventillation has been maintained.
The ceiling (artexed) under the tank platform now has a beige tinge to it, caused presumably because the loft is now colder than before the insulation was increased, and damp is condensing in the plasterboard in this area. A max min thermometer showed the loft space got down to zero celcius last week when it was -3 outside.
Options which have occured to me so far are:
1. Build a box out of polystyrene slabs covering both tanks, the platform and the adjacent pipework, sealed to the ceiling, and bring the loft insulation tight up against it, so the temperature inside the box can rise due to the warm rooms below, but the temperature in the general loft area can go right down to exterior.
2. Insulate under the tank platform to the same standard as the rest of the loft and arrange some trace heating to stop the tanks and pipework from freezing.
I prefer the first idea but I don't know what conditions would be like inside the box. High humidity perhaps leading to mould? And what would happen when it is 35 degrees up there in summer?
Has anyone tackled this problem or got any better ideas?
