Hi guys, my heating kit is as follows:
- Worcester Greenstar boiler (around 3yrs old)
- Drayton LP522 programmer
Just recently, the heating isn't responding when I click the 'advance' button on the programmer. This has always worked fine until now. The programmer light comes on, but the boiler doesn't fire up. To get the heating running, I have to turn on both the hot water and heating, which fires the boiler up, and then turn off the hot water, and the heating continues to run.
If the programmer reaches the end of its timed period and turns off, or if I turn it off manually using the 'advance' button, it works and turns off the heating as normal. So it's just the 'advance on' whioh isn't working for some reason.
What could be going on here? What's the likely culprit? Thanks in advance.
