Simplest boiler
Status
Not open for further replies.
What is the simplest open vented heat only boiler? No vessel or pump inside. It only needs to give a constant temperature and not modulate to the room temperature. Just a simple boiler.
I may have an older style boiler still unused in the box (if I have and your interested (up to you what you do with it) but they should not be newly installed.
in all seriousness any heat only will do, they all modulate their output but the temp stays at what you set it at the boiler thermostat.
for ease of use i would say the logic, 2 control knobs on the front (on-off and system water temperature) doesn't get any simpler than that.
This looks simple enough. But it is an Ideal who have an appalling reputation.
'John was overcome with joy when he realised another rubbish thread was heading towards 3 pages of nonsense'
If the OP wanted proper professional advice he would explain what he wants the boiler to be used for so that we could give the best and most appropriate advice!
The IG would be a possible choice.
But I suspect he actually wants the cheapest and not the simplest one!
Tony Glazier
Tony Glazier
What is an IG? I write "simple" not cheapest.
I think John wants the boiler that would cause the most confrontation and difference of opinion possible.
Just to save you the effort...
No content.
Status
