Strange Noise From attic
27 Feb 2015
Aberdeen
ok i know nothing about my boiler all i know it that there is pipes and a big thing in the attic that it above my airing cupboard. So every now and then the attic makes a very weird noise that sounds like a old fashioned steam train and when open the attic the pipes running down the central beam of the roof are moving slightly and downstairs the radiators are slightly vibrating. the even weirder part is that about 2 months ago it was very prolonged and we heared water so we paniced. however when we looked out the back door we realised some sort of overflow pipe was pouring very hot water from the roof. when we saw this we thought the worst and grabbed the ladder and got straight into the attic only to find thick steam covering the roof to the point you couldnt see it.
i thought i might add that a month before that incident a pipe was replaced because it split or something and ruined all the paint down the walls and on the ceiling. anouther thing is that we live in a bungalow so its all lower down.
Thanks in advance
Get it looked at. If there's boiling hot water pouring from the overflow then there is a serious problem, and lives could be at risk. If the system is boiling the contents of the cold storage cistern then there is a high risk of it collapsing, showering anyone in the room below with scalding hot water.
A baby died as a direct result of a similar incident a few years ago! Dont take a chance.
JESUS! the plumbers have been called! thank you very much!
