Hi
My kitchen designer (read: me) has made a bit of a cock up. I had to re-arrange the layout at the last minute as the client (read: my wife) wanted a lot of smaller cupboards to replace a two larger ones. I rearranged it all as per her request, and it arrives next week. There is no more opportunity to change the layout. The problem that I made is that in acceding to her demands, I removed the two 600mm+ base units that could accommodate a plinth heater. The plinth heater is electric, and the only source of heat that I can put in the kitchen.
I am now left with the following choices:
1) Install under integrated fridge freezer. This seems a terrible idea for obvious reasons, in particular given the steps I went to in order to avoid having the FF next to the oven.
2) Install it under a larder unit at the entrance end of the kitchen. This is not ideal as it is at the warm end of the kitchen, a good 3.5m from the back door, and so will not do a very good job of heating the room.
3) Install under the sink. This seems like a pretty stupid idea – a leak in the plumbing could see water getting in to the unit. In addition, I’d have to put the FCU a long way away as I would not want it anywhere near the sink.
The other base units in the room are: 3x 400mm units (not adjacent); 1x 300mm unit; 600mm tall unit for double oven; integrated DW and WM (no space for a plinth heater).
Any advice would be welcome!
