LED Lights in bathroom over shower
OK guys, thanks for all the replies!
For the light over the shower should I put something like this in
Housing
http://www.ledhut.co.uk/drivers-fit...nlight-fitting-ip-65-2-options-available.html
Then can I put in a 4.5W LED GU10 spot light into it which is on a driver?
Light
http://www.ledhut.co.uk/spot-lights/gu10-led-bulbs/new-4-5-watt-gu10-led-350-lumens.html
Driver
http://www.ledhut.co.uk/drivers-fit...ansformers/6-watt-led-transformer-driver.html
The lamp you have linked to is 240volt and does not need a driver.
I am beginning to think you are not competent to do this and should call in a sparks.
Qualified no, competent i'd say I was fairly competent but know when to ask questions if i'm not sure about something hence posting in here for some expert advice.
I seem to have opened a tin of worms with some of you though!
To clarify things then - If I put a sealed unit in above the shower can the LED be on mains voltage
OR
do I need to put a low voltage light in there which is on a driver?
Thank you
HIGH voltage:
Not because you can't reach it.
I agree but until the manufacturers change their (actually wrong) labelling it is bound to persist.
There seems to be something wrong with those in charge (lately?).
Especially the fire-resistant CU fiasco.
The IET forum is discussing such things and some have contemplated using the European regulations, where plastic is still allowed, as a departure.
Housing
Light
Driver
OR
Thank you
Once again.
Mains voltage is LOW VOLTAGE.
Read this tin of worms you are referring to.
Its only one light, splash out on a nice 240volt light that states on the packaging that it is suitable for a shower then you cant go wrong.
not only will it be electrically safer it will also seal better and reduce damp etc entering the ceiling void
As I've said, I really don't think the problem would go away (at least, not for a very very long time) even if every manufacturer and retailer labelled things 'correctly' (this issue only really relates to ELV things - I can't recall a consumer 230V/240V item ever having been labelled "low voltage").
I believe there is a very strongly entrenched belief on the part of a high proportion of the buyers/users of electrical items that "low voltage" refers to what you would call 'ELV' (maybe not even including voltages in the higher part of the ELV range) - and that nothing is likely to change that in a big way for a very long time.
I believe that change would/will be slow/difficult because the 'correct' terminology just isn't rational or intuitive for the general public. They are only likely to ever encounter electrical voltages between, say, 1.2V and 240V - so why should they regard it as reasonable to describe 240V as 'low voltage'? As I've said, LV is 'low' only for those in the electrical supply industry and a few other industrial settings.
You used to see HIGH voltage stickers on 440 volt stuff.
Was 440 ever High voltage , i dont remember
You used to see HIGH voltage stickers on 440 volt stuff. Was 440 ever High voltage , i dont remember
I don't know. However, unless I'm dreaming it, wasn't there a time when there were "DANGER - HIGH VOLTAGE" labels and stickers all over 240V things? (which, to the general public, would seem reasonable, both then and now).
You may be right, as most of my works 3 phase its hard to recall what they were stuck on, they were also usually RED
Well the oldest regs book I have 1976 states a red and white danger high voltage label for voltages exceeding Low voltages, low voltage defined as 50 volt to 1000volt
Fair enough. I was actually thinking more about warning labels on consumer products, rather than what the regs required in installations.
