So what you need to do is:
1. Test your voltage tester with a proving unit.
2. Isolate the circuits in question.
3. Test across all cores and check zero volts is present.
4. Prove your voltage tester again with your proving unit.
5. Connect the cables back as they were in the accessories within a MF junction box
6. Carry out insulation resistance tests.
7. Carry out R1+R2 tests
8. Check results are within parameters set out in BS7671.
9. Turn on electricity.
10. Carry out earth loop,impedance test following safe live working procedures.
11. Check results are within parameters set out in BS7671.
How can we realistically expect a DIYer to do steps 7-8 and 10-11?
Does it need to be done in order to achieve a safe and complicate job?
By telling them that they must not attempt any electrical DIY work until they have acquired the knowledge, skills and equipment of a properly-trained electrician? ... or perhaps that they have to read a dozen books (list kindly supplied) before they can get their living room lights back on?How can we realistically expect a DIYer to do steps 7-8 and 10-11?
That's not really the question, nor the point.
How do you expect a DIYer to complete these steps in any order? Or are you simply blowing through, showing off your apparent knowledge, without any attempt to help anyone? If so, then I applaud your intellect and experience but question the value on this thread.
(and I presume you mean "compliant" rather than "complicate"?)
I don't expect a DIYer to knock down walls in their house and think it is ok to just chuck the cables into a JB and throw them in the ceiling.
Accepted, as in recognising it's existence yes.What you expect and what is reality are very different ... But ignorance in a DIYer has to be accepted
No, no, no, no and no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no.even if it means leading by the hand with simple but detail instructions "put the red wire in L2 and the black wire in COM "
