Do you mean the MCB is off, or the fuse has been removed?The fuse which supplies the garage is down.
That's micc commonly known as pyro cable. You will need an electrician who has experience of working with this sort of cable. Not all electricians especially younger ones will have the skills or tools required.
This is not a DIY job.
//www.diynot.com/wiki/Electrics:MICC
Quite so - it's not even a job for a substantial proportion of otherwise perfectly competent electricians.Wow. I know there are frequent debates on here about what's suitable for a DIYer and what's not, but that link makes it absolutely clear why terminating pyro isn't a job for the amateur.
It's probably not that simple. In the case of working with and terminating pyro, as you've seen, it is quite clear from the link that it is a complex task which requires appreciable skill/experience and the appropriate tools. However, in the majority of cases of things which DIYers (or, at least, particular DIYers) should leave to professionals, the task would probably look "easy enough" when described/illustrated in a similar fashion, so would probably not have the same impact on prospective DIYers.Perhaps if there were similar quality links for some of the other tasks that DIYers enquire about it may be easier to persuade them (sorry, "us") when they absolutely should bring in a professional?
Subject to the disclaimer that I haven't actually tried it yet, I don't think there's anything "clear" about it being an intrinsically unsuitable job.Wow. I know there are frequent debates on here about what's suitable for a DIYer and what's not, but that link makes it absolutely clear why terminating pyro isn't a job for the amateur.
That's all true, but I think we both understand what skotl meant. As you say, it is pretty apparent that it is a task which requires an appreciable amount of skill, gained through experience/practice, and the acquisition of suitable tools etc - and therefore is very rarely going to be appropriate for an 'occasional DIYer' (which is what the vast majority of 'electrical DIYers' are).Subject to the disclaimer that I haven't actually tried it yet, I don't think there's anything "clear" about it being an intrinsically unsuitable job. A not inconsiderable amount of practice would be necessary, I'm sure, requiring time and financial investments, but that doesn't equate to unsuitable.Wow. I know there are frequent debates on here about what's suitable for a DIYer and what's not, but that link makes it absolutely clear why terminating pyro isn't a job for the amateur.
That's where the required 'experience' element comes into the equation. FWIW, whilst the description does not explicitly mention (or illustrate) core-to-sheath insulation tests, it does say "... then carry out another insulation test to ensure the cable is fault free....", which I think most people would probably take to include core-sheath as well as core-core tests.Unfortunately the link omits to illustrate the core to sheath insulation tests that are essential - and how to get an acceptable value if it is low. Being shown how to do something (at least once) doesn't necessarily impart the variety of "what ifs" that invariably crop up during any technical task.
It is probably the case that most people won't want to bother making the investments.That's all true, but I think we both understand what skotl meant. As you say, it is pretty apparent that it is a task which requires an appreciable amount of skill, gained through experience/practice, and the acquisition of suitable tools etc - and therefore is very rarely going to be appropriate for an 'occasional DIYer' (which is what the vast majority of 'electrical DIYers' are).
Indeed, but not for any 'disreputable' reason - merely because, for the vast majority of 'occasional DIYers' the amount of 'investment' (in terms of time, effort and money) just wouldn't be justified by the very little use to which the skills and facilities would be put.It is probably the case that most people won't want to bother making the investments.
Yes - but, as I said, we both know what he really meant - that (for the above reasons) it isn't a job that would be appropriate for the vast majority of 'amateurs'. Indeed, I don't think it's primarily an amateur/professional issue - even though the 'investment' would probably be more justifiable for at least some of them, I would imagine that, as things stand, its "not a job" for a substantial proportion of electricians, either.But skotl said "terminating pyro isn't a job for the amateur".
