Yep, fully aware that the lever on the side is not relevant to this.
I had removed the cover and was observing the internal mechanism.
I must admit to having a sneaking admiration for the design of the valve now that I understand it better.
Its a very clever but simple piece of engineering, and is a joy to watch it working.
However, it does have one fly in the ointment, and that is that if CH was the last option called before the controller switches the system off, power will remain to the motor. This causes the motor (and therefore the actuator housing) to get warm, and aside from using a small amount of electricity, it will likely help shorten the motors life.
I've 'fixed' this by now ensuring that the last program to be called is always HW, followed by a system shutdown. That way there is no power remaining to the Honeywell, and the valve remains at the HW (B) position.
Now the only risk is that the rubber ball valve will begin to indent, and eventually allow water to seep through, but that's for another time
As I noted in my previous post, the Honeywell is no longer a suspect, the problem lies somewhere else.
I just need some help trying to work out how to find it.
