Yeah I thought that it was the removable chuck which was what I was drawn to so I can use my normal drill bits with it to cut large holes since I already have the hole saws and quite a few bits.
Thanks I have been rooting around as well and I have found these which apparently are really good...
http://www.ebay.co.uk/itm/Bosch-5-p...32-/181804969454?_trksid=p2141725.m3641.l6368
the X5L range. Have you had any dealings with them? They will be used for concrete / reinforced concrete and brick mainly I don't think I have anything which I will need them for big wooden things but I suppose I could get ordinary bits for that and then use the power of the drill to get through the wood if needed.
I presume that SDS drill bits will go into the SDS plus drill?
James
James
