I'm doing some self learning for ACS. I've been reading about gas hacks and thought I'd share for the other engineers.
So when you're at a customer property, do the following checks:
Also, dont let on that you know there's something dodgy going on otherwise you might end up like this guy
- Check the meter and ensure the security shear nuts are fitted (these are always fitted to meters < 2 years old)
- Visually inspect the meter and look for signs of tampering
- Check that when a gas appliance is on the the meter dial moves smoothly, any stuttering or jamming and something's fishy.
- If you suspect they've changed the meter, discretely make a note of the serial number and call National Grid afterwards to investigate
