- Joined
- 29 May 2007
- Messages
- 20
- Reaction score
- 0
- Country
Good evening everyone. I would be most grateful if anyone could help me with some problems.
About 12 years ago, I installed a closed loop oil fired central heating system and everything has worked OK over this period.
Unfortunately, about a week ago, the circulating pump shattered internally and blocked the flow of water through the system. The pressure relief valve opened and emptied the system.
I obtained a new Grundfos replacement pump and fitted it into the system. When I refilled the system, I found that the pressure relief valve was faulty - water was pouring out of the outlet.
Water was also seeping out of some of the 3/4 inch soldered joints on the copper pipe.
I replaced the effected copper soldered connections with compression fittings. I also replaced the
pressure relief valve. The original pressure relief valve had a male head which fitted into a female
socket on a T piece. The new valve has a female fitting. To fit the new valve I had to use a female to female adaptor.
My problem now is that I have leaks in the system which I am sure is due to incorrect sealing.
It is 12 years since I installed the system and I have forgotten a lot and I need some help.
How do I seal the female to female adaptor? - I have put Boss White on the threads but this seems to be ineffective.
I also have a leak where the pipework connects to the burner.
Any information would be most welcome
Many thanks
Jimmy
Many thanks
Jimmy
