Hi All,
I have a main thermostat on my wall in my main hallway and a second one in my conservatory working 1 radiator in there. All of a sudden the second one has stopped working. I bought a second hand same model off eBay as its no longer made and that was said to be working ok.
However after replacing it it still doesn't work.
I have no idea what else to check. I believe the wires goto my airing cupboard upstairs as there is a joint box on the wall which is where a bilermate was until I had a combo boiler fitted and that was removed.
Any ideas if theres anything else I can check? fuses anywhere etc... I have to assume the new thermostat works so don't want to buy another. I'm also concerned buying a newer model in case the wring is different. On this one there is a blue on 4. white on 3 and brown on 1.
Current thermostat is a Horseman HRT2
working main is a drayton digistat
Thanks in advance.
Thanks in advance.
