Back to the original topic. If you ever speak with DNO people they will often tell you that its LV that they fear the most. 11kV and above tend to be arc risks - you get blown back as you approach the equipment. Also its worth noting that MV and HV equipment normally has several layers of safety - you would have to be deliberately reckless to come into contact with a live MV or HV contact that hasn't been fully isolated (or your working under an appropriate live working regime).
LV is lethal because for three reasons. A) its less likely to be fully isolated B) live working is more likely to be permitted for reasonably complex tasks (its only really used in HV for very basic maintenance) C) when you make contact with an LV circuit your unlikely to be blown away from it, you may simply cling onto it.
I believe that when the British Railways Board was experimenting with different voltages for overhead electrification in the 50's, they set up a line out of Glasgow Central and used various transformers to test different voltages. One thing they found was that trespassers on the railway who came into contact with 25kV equipment needed burns specialists, whereas those who came in contact with <3kV needed a coroner.
I would much rather be seeing a burns specialist than a coroner any day.
