- Joined
- 9 Feb 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi there,
I'm hoping someone can help. I've just moved into my first own home and am trying to get things sorted out. The issue is with having to have the hot water on for the heating to work. I've had this issue before in my old place and it was usually the Honeywell 3 port valve that gets stuck. In this case I've had a heating guy come and change the Honeywell valve, service the boiler, flush the CH system, bleed etc.. After it was all done the issue was still there. The guy mentioned that the control panel is faulty and I've installed the Hive now but still the same issue.
I'm now looking into this myself as he doesn't to seem to have a clue. If anyone could guide me on what to check I would really appreciate it. The boiler doesn't fire up with just the heating switched on but when I switch on the hot water the boiler fires up and the radiators get warm. The hot water works fine, the issue is just with the CH. As mentioned Honeywell 3 port valve has been changed and the guy checked to ensure the new valve was not getting stuck.
Details
Potterton Suprema boiler
Shower pump installed that powers 2 bathrooms
Picture of HW cylinder and setup attached
Any advice on what to check would be really appreciated.
Many thanks
Kaiser
Details
Many thanks
Kaiser
