ID this systemsystem
1 Dec 2009
East Mids
Come on guys help me out, powder coated Ali outside/timber inside, what system is this?
Residence 9 only do foiled finish I believe so Im thinking the plain PVC on the outside rules that out.
Is that real timber cladding internally?
Is the frame 100mm thick?
Residence 9 is fully PVC.
I have heard of composite windows that are timber inside and aluminum outside (I have a sample somewhere, they are called Velfax or something along those lines).
But I have never heard of PVC with timber cladding
These are Ali outside though
It's not r9. To me it looks like a standard upvc door with some kind of different foil inside
@God, its defo an Ali door and Ali frame, the slab is as thick as a composite door 44mm but then on top of that inside it has real timber making the door thicker still, this picture hopefully shows its defo timber not a foil. Just need to find a supplier for the panels as they've discoloured, its all externally beaded but only the vertical beads, the horizontals and fixed/part of the profile as there is no joint there to get a scraper in which suggests the dgu and panels are shuffle glazed in
