Hi.
I am about to replace an extractor fan. It has a switched live, live and neutral but no fused spur.
It was fitted incorrectly.
Outside the bathroom there is a 3 gang light switch.
Initially, the far left rocker switch powered the ceiling lights. The next switch controlled the fan BUT only when the lights were on (the 3rd rocker controls a wall light and can be ignored).
Having locked at the wiring in the ceiling I have now discovered that someone attached the fan's "permanent" live to the ceiling light's switched live.
I have re-wired the connections in the ceiling, the "permanent" live and switched live are now correct. The fan now operates independently of the ceiling lights. The middle switch turns the fan on and off but it acts as a controller rather than an full isolating point. The permanent live which has no isolation point allows the timer over-run.
I know that that there should be a 3 pole switch outside the bathroom and a 3amp fused spur, but there isn't and if I am being totally honest, there won't be one for the foreseeable future. The fan is only accessible from a step ladder.
Given the above, I would be happier if it had overload protection. I am considering using two in line fuse holders.
http://uk.farnell.com/bulgin/fx285/...crid|78108293829|&CAWELAID=120173390000291244
I guess that the most sensible place to fit them will be in the fan (assuming sufficient clearance/space).
I completely appreciate that my suggested set up is far from ideal (read:legal) but I would rather improve the set up, even if it still falls short of the requirements.
Being realistic the other option would be to ignore everything and leave it as it is.
</ducksForCover>
</ducksForCover>
