i have a really strange problem with my glow worm hideaway 60 b boiler I hope someone can offer advice on. Since putting fernox f2 boiler silencer in to quell some minor kettling noise which was only moinir hissing on heating up rather than banging etc, now when the boiler has reached or is reaching its set heat output (boiler only set to half way) there is a sound of tricking gurgling water/air passing through the boiler/pump. This then passes to the nearest radiators in the hall and dining room producing a trickling gurgling sound in the radiators but I never find any air in the radiators. The situation is even worse if the boiler is up to temperature and you stop the pump allowing the boiler temperature to climb further and then start the pump again, the noise of trickling/gurgling water is terrible and alarming.
I have checked for water leaks by tieing up the fe tank float for 5 days and the water level stays the same. There are no signs of water leaks around the boiler either. I have checked to make sure that when you drain water from the system the water level in the fe tank falls. I have also checked that there are no blockages at the feed T to the system using a magnet. I have placed a cup under the vent pipe for 2 days and no water is in the cup so I guess no pumping over. I have placed a cup of water under the vent when the pump starts and initially a small amount of water is sucked up but released as soon as the pumped water reaches equilibrium. The hot water is gravity fed and the boiler is heating up the water tank as normal.
Turning the pump speed up to 2 helps the problem as the boiler doesn't reach the temperature set at the boiler stat very often compared to when the boiler is cycling more on speed 1. When the tricking/gurgling starts it diminishes as soon as the water temperature in the boiler starts to fall. When the boiler heats the water up form cold it is silent until it reaches the higher water temperature set on the boiler stat. When the boiler cycles in and offer around the boiler stat temperature the problem is worse.
As I can never find any air in any in of the radiators is the boiler experiencing localised steaming due to kettling which the fernox f2 boiler silencer is making worse and pushing through the pump to the radiators in the dining room and hall. Fernox say it should improve heat transfer and break larger steam bubbles down into small ones during kettling. How could these steam bubbles be reaching the radiators before they cool? Should I just drain down and refill my system without the f2 or could I have sludge in the boiler that is boiling and then being pushed round into the nearest radiators? The problem is really peculiar.
