Hot water turning Luke warm from boiler
12 Sep 2008
Cheshire
Hello
Bit of a strange one.
Our boiler (Viessman 35kW) provides our hot water. It starts off fine and hot but a few minutes later the water runs luke warm. When it's running luke warm it heats up to hot again temporarily when another hot tap is run but then quickly goes back to luke warm again.
When in the shower the water changes quickly from hot to luke warm.
Looking at the boiler when the hot is running it goes up to 70 plus deg then drops down to 40 ish.
Seems very strange - anyone any ideas?
Alan
Yeah I'm going to get the gas engineer that services the boiler. I just thought it was a bit strange that it comes and goes.
Well I don't understand , if your going to get an rgi to look at it why would u seek for the answer in advance.???? Maybe you should get advice from the rgi and then relay to us what he or she thinks the problem is ?
Because I've never found it a problem to have some information as to what may be the problem. Always helps in understanding whether the rgi's diagnosis sounds reasonable. I've been managing building projects for fifteen years and I know that tradesmen aren't perfect. If you took your car to the garage with a strange fault you might research it first, no?
But I'm not a gas fitter - hence why I am on an advice forum asking for advice. Apparently that's not what a forum's for.
But you have had no diagnostic from an rgi have you not ? , and for me to give advice about a gas appliance to a diyer is a no no I'm afraid , if you have been managing building projects I'm sure you may have a list of rgis that can help you rather than posting on here, also if my car goes wrong I have the perfect guy to go to :mrgreen:
If you do get advice on the potential problem, would you then ask for a potential price to repair? Then use it against the rgi whom may not agree with the price nor agree with our diagnosis?
rig
No. But if someone helpfully noted "I had something very similar and it was X" and the RGI turned up and said "Boilers f@cker, needs replacing", I might then consider getting a second opinion. I'm not going to ask anyone who's not inspected for themselves about costs.
I don't think I'm being unreasonable in asking for advice.
No but u haven't had an inspection yet so u cannot yet make judgment can you ?, twot
