Internal check valve outside tap
9 Aug 2009
Blackpool
When fitting an internal double check valve for an outside tap, is there a max distance it can be from the outside tap. Obviously its on the pipe after have tee's of for the tap supply and after a iso valve.
Jeff , what's happened to Tony Blackburn ? All seems to have gone quiet. Have you found someone else to listen to?
I can't talk about it. I lay in bed crying and drinking Gordon's or Hendricks most days.
He will be back when he's sued the BBC.
