in a modern clean-burning multifuel stove, I think you will be permitted.or smokeless fuel
They slide upwards and pull out vertically...Thanks for clarifying that guys, so now I can safely assume that it's definately a coal room.
I can't check it now as it's late, but there is no bolt on the inside, so how do I open it?
I think that you have three main options :- one is to tank the cellar properly, so making it water tight, so your ventilation has only to deal with ordinary levels of dampness due to your breath. Two, building a lightweight "shed" inside the cellar, whose main claim to fame is that it is impervious to water vapour and has perhaps some insulation added and three. do what the Americans do, and that is realise that the water ingress can't be stopped so build a proper room on concrete foundations inside your cellar with a drainage channel between the two walls which ends up in a sump. Install a pump to periodically pump the water out of the sump into a local drain.
Frank
Any stove that is DEFRA approved can be used in smokeless zones. You are allowed to have a smokey chimney for 20 minutes to assist lighting until it gets up to temperature.
