Sorry to confuse things, I was thinking just between hot and cold pipes, as you describe above, though I wasnt thinking straight as you did say it was all metal after your meter.
Some parts of the building im in has plastic for hot and cold then 2metre copper drops to the hot and cold taps, at the time the installer felt the need to crossbond between the 2 copper pipes.
At work im being told things about water creating a path from the extraneous bit through the insulated bit to the cold pipes and creating a risk of a voltage between the cold and the hot pipes, that in my case i assume are picking up an earth via the earthed electric water heater, though wouldnt that risk be negated by the main bond prior to the insulated bit on the cold anyway.
Then as you mention the risk of the Floating bits and the earthed via the heater bits.
To be honest im getting more confused, everyone at works telling me different things
