As TTC has advised, the pipe chase is the best option to get from to the bottom. You can run from the loft down the inside if a fitted cupboard and under the kitchen units by removing the kick boards if the soil pipe runs through the kitchen.
I have just wired a timber framed house for AV and apart from the insulation in the external walls, (as you would expect), all internal walls were clear of any vertical obstruction.
DS
DS
