    Dismiss Notice
Awkward cable run in stud wall
Discussion in 'Electrics UK' started by Yangers, 5 Apr 2016.
  1. Yangers
    Yangers
    5 Apr 2016
    4
    Thanks Received:
    Country:
    So I have a light switch in a stud wall. I want to cut a door in the wall where the switch is and move the switch to the side. I know cables should run vertically. But my issue is I cant access the ceiling void without cutting a hole in the ceiling to move the cable over. Can you run the cable horizontally along the top of the stud work then vertically down to the switch or do I have to cut a hole in the ceiling and drill the joists to move the cable over?
  2. Adam_151
    Adam_151
    17 Jun 2004
    6,503
    Thanks Received:
    243
    Country:
    Within the top 150mm (6 inch) of the top of the wall is a permitted cabling route, as is within the same distance of a corner.
  3. Yangers
    Yangers
    5 Apr 2016
    4
    Thanks Received:
    Country:
    Grand! Thanks.
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,064
    Thanks Received:
    1,913
    Oxfordshire
    Country:
  5. DaveHerns
    DaveHerns
    11 Nov 2009
    2,583
    Thanks Received:
    207
    Country:
    How do you plan on extending the cable?
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Why?
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
